View Full Version : LS1 Based Engine Tech
- Big LSx race headers
- I broke something.
- 98 Formula LS1. Starts, revs to 3000 on it's own... DIES!! Help
- 5.3L cam specs
- oil moisture under throttlebody area
- 98 Formula LS1 won't start. Cranks, no spark!
- G5x2 + PAC 1518
- intake + wp = ??hp just curious
- New Toy coming tonight!
- overheating or low coolant?
- compression check?
- LS1 surging and lurching, I really do not understand it!?!?!?!?
- ls2 coils on ls1??? possible?
- meziere EWP install...tips for Fbody..
- Need help - Intermittent bogging problem
- bleeding ls1 coolant system
- A 2001 m6 z28
- Vacuum Lines to Vacuum Solenoid
- 408 iron block problems
- Pin # on a 2002 z28 for a Shift Light???
- LS1 Camaro heater core hoses? Where? What?
- Cam only ls1
- video of my new best
- hesistation at idle
- folks i need some help!
- will I meet my 375rwhp goal?
- Anyone ever tried out the Typhoon manifolds
- LS1 to 5.3 Head Swap
- Which Heads Are They? 706...
- Misfire Help
- Best way to get to 425 hp
- Complete electrical shut down,even with cables.
- heads and cam for ls1
- 00' LS1 T/A Exhaust
- Missed my goal
- do I need a tune?
- new to ls1
- Any Recommendations?
- air boxes
- LS1 engine haunts
- Introducing the Fiber-Tuned Intake Manifold
- Pinks All Out May 2009 in Indianapolis
- Porting stock heads?
- Fix broke starter ear of block?
- Opinion's on The 98-02 LS1 Camaro's???
- finnaly got an 01 ss
- Vacume leak at iac valve
- Hp increase ?
- New Toys
- LS1 newb ?
- Clutch Pedal Noise
- Head/cam swap on 2002 SS
- 1/4 mile predictions. 98 SS
- EGR AND AIR Blockoffs
- lq9 engine
- Valve cover removal on an LS1?
- Wideband O2 sensors?
- header install question
- Low Fuel Pressure in LS1 Transplant! PLEASE HELP
- Blocks, heads, intake and PCMs
- Clutch or motor mount or what?
- PCM Codes, bad oxygen sensor? Help! Thanks
- Best Cam For An LS1 Engine???
- Am I insane? Complete powertrain swap, 2000 Z28 to 93 TA
- how good are the lloyd elloits ls1 packages
- what's a 6.0 worth?
- Flycutting
- Bi-Tron additives: Sensational claims or real?
- Kinda weak on the bottom end
- Catch Can w/out PCV valve
- Good Buy
- What does this hose go to? EGR?
- 02 Sensor location help.ha
- burning oil
- Help needed.........
- another new best 13.434
- Which air lid is the best
- LS! Block Strength??
- multiple alternator failures.
- Here comes winter...
- Throttle cams and throttle cables.....
- Help me out!!
- BS3 and Sensor Wiring
- intermitant Lean condition...
- Please confirm or raise your Flags on this car
- Trans Am Intake
- Weird Noise
- Diablo Predator
- Dyno's a bit low?
- Check Gauges light?
- Got a question
- Supercharged LS1 slow!!!
- ls intakes?
- cheapest way to hit 410rwhp?
- F14 install and Dyno numbers
- I think i'm gona do a LS1 in my 70 Z28
- what are the best plugs
- Ls1 numbers?
- Difference Between The LS1 and LS2 Engine's??
- Upgrades with my heads and cam install
- new to the ls1 scene....
- Check it out FIPK owners
- another new best 13.496
- will i need a tune instantly after long tubes
- 98 => on LS1 Ttemperature Gage
- Ticking after gettting on it hard.
- Iron 6.0 vs LS6?
- An LS1 that hasn't been run in 2+ years at ALL...
- A4 vs. M6-Which would you get?
- overheating
- ls1
- 1999 SS question please help
- 99 Z28 need some wiring help
- Car is over heating.... Please help!
- Is this the correct way to measure lifter preload?
- Question about some part of the air dam assembly.
- Stock Valve Spring Height vs Aftermarket?
- What Valve Springs are these? (Help Identify)
- Oil-Burn question
- LS2 Fuel rail covers
- Knock coming from my T/A
- TS 228R cam
- EGR block off plate + tune?
- LS1 Heads (241's) milled to .050"??????
- Pros and Cons of buying a SC LS1 M6?
- Is the ls6 intake worth buying
- 13.5 at the track new best
- need a opinion on clutch for ls1 t56
- Bad mileage, hesitates
- LS1 VS. 1st Generation 402 Big Block???
- Nick Williams 90MM TB and IAC
- Just Got My First Ls1 Need Help
- Running too lean..?
- A/C recharge
- Problems taking off
- Thinking about an LS1 Car instead of my BB 69 Camaro but???
- 99' SS! What do I get???
- 2500 RPM lag?
- Heads and Cam question
- Plug Wire Question
- LS1 Water Pump R & R?
- Same O2 sensor part# for before and after cat?
- 100k miles 98z28
- Replacing my Z-28's Lt1 with a LSX?
- took some time and saving but finally got a ls1 ss
- Took the 02 Z28 down the track for the first time yesterday.
- cross section of LS head
- LS6 Intake Question
- Zo6 Cam
- Odometer is not stored in the cluster, right?
- ls1 info
- Mods that will improve MPG???
- first time at track with ls1
- Ram Airs?
- new to the ls1 n20 ?
- LSx swap into b-body
- New to performance on ls1
- What is this thing next to my horn?
- Lt1-to LS1 swap
- Drive cycles and fully completed OBD
- pop goes the weasel
- Help Needed Troubleshooting Valvetrane issue. Pictures
- Bad gas mileage
- SSRA vs SS hood ram air
- 1st ever dyno pass!!!
- Power Steering problem - anyone else have this?
- little click, big problem
- A little help please
- k&n fipk
- Can Lid and Stock shaped filter have equal power gains over induction tube system
- 95 Camaro Z28 - LS7?
- B&B Ripper Shifters - Opinions?
- which throttle body gasket
- bad head gasket?
- Ran a compression test on my 98 LS1, tell me what you tnk.
- build-up on my ls2
- ls1 offroad go fast parts
- PRC LS6/LS2 Heads Get A Face Lift!! 225cc Runners & More!!!
- 2000 SS M6 -- Duhh: Where is the PCV?
- lid question
- 5.3 swap into a V6 firebird.
- Has anyone used LS1 Granatelli Big G Tuner?
- What is this?
- last spark plug p/s
- jason cromer still around?
- Working on a P0410 code / 2000 SS M6
- Help with New z28
- oil pressure question?!?!
- Looking at First Camaro, What to Look For?
- new cats
- 98 Z28 Won't Start
- What exactly is the weak spot in the LS1 bottom end?
- possible to just replace battery cable end?
- ls2 swap updated pics
- Lt-ls
- Idle issues and loss of power???
- Different Backfire issue
- LS1 MPG & Gas
- withh this work on 2000 firebird?
- Using Cable From OBDI W/OBDII Conector On a OBDII Car?. (Messed Up Gauages)
- Oil leaking from the pulley, yes I screwed up
- after header afr?
- LS1 Overheating Question
- Need help with PCV tube!!
- What does this go to?
- 12557335 A/C pulley - sending out feelers
- Thinking of 5.3 LS swap.....
- Ok help me pick a cam.
- 97 & 98 corvette owners regulator related
- R&R of the TPS
- I've been waiting to say this for a while....
- new car help please....?
- LS1 A/C idler and tension pulleys??? '99 SS
- A little walk through of our stage 2 LS6 heads :)
- Crankshaft Position Variation Learn
- better luck with delco or bosch 02 sensors?
- Question about LS1 Blancer/Crank Pulley.
- Dyno Results: F13/Patriot Stage II LS6 heads
- spark plugs?
- 5.3 literv-8
- Need help with codes (1416 & 0430)
- Bare bones cam swap
- 6.0 conversion
- pcm tune...
- Going to buy 2000 Camaro Z28 MNB M6 34,000 miles
- My ebay header installation experience...
- Developed a miss...
- tunners
- Lt1 gas mileage and fuel requirements
- LS1 with engine knock
- crazy idle
- 5-Pin Maf diagram or pin out?
- cam question
- Heads and Cam - DONE! (vid) <3 Kraest
- Newby to Z28
- DTC' s PO131 PO151
- 10mpg?
- Intake, throttle body, and Manifold
- O2 sensor going bad?
- Wtf?
- Best Spark Plugs???
- spark knock
- fidanza clutch?
- Great power for Bolt on's
- Do the numbers seem right?
- 2000
- arp head bolts on a ls2 (searched and cannot find answer)
- motor start up vid
- obd2 code 430
- LSX in my 94 Z71
