Catch Can w/out PCV valve
Old Oct 14, 2008 | 01:52 PM
350pride's Avatar
I posted early about how much oil my car was burning. After doing some research and looking at my car, I have discovered that my car uses a catch can, and that there is no pcv valve on my car.
Now my question are: why is there a catch can? What does it do? and why would there be no pcv valve? would not having a PCV valve cause a substantial increase in oil consumption (1.5 courts every 300 miles)?
Thanks,
Pride
Old Oct 14, 2008 | 02:17 PM
Chrome383Z's Avatar
You should still have a PCV valve even with a Catch Can.
LS1 engines are loose and typically use a quart of oil every 3k miles or so.
No PCV valve could cause some idle/part throttle issues and maybe even detonation problems at WOT with no regulation of the flow... i'm not sure.
But regardless 1.5quarts every 300 miles? Somebody is terribly wrong. I'd run a compression test.
I'd put a PCV valve in as well, but I don't think that's all your problem.
Old Oct 15, 2008 | 01:04 PM
BadgeZ28's Avatar
The Pcv valve should be located at the rear driver side valve cover. The pass side also had two vents. One goes to the throttle body. Most boosted cars remove the hose to the throttle body and use a catch can and run the out to the intake side of the turbo or supercharger. This prevents boost getting into the crankcase. I have no idea why you have a catch can as a sub for the stock pcv system.
Old Oct 16, 2008 | 12:25 PM
Chrome383Z's Avatar
Tend to be popular over at LS1tech to help prevent oil getting into the intake given these engines seem to be loose.
RX Speed Works
Aug 11, 2015 11:16 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
NewsBot
Jul 8, 2015 06:47 PM
