TS 228R cam
Old Aug 20, 2008 | 12:38 PM
spltblkribbon's Avatar
TS 228R cam
How is the reliability on this cam? How much of a difference in power is there from the 112 LSA to the 114 LSA? Would this be a good set up for a daily driver?
Old Sep 1, 2008 | 09:34 PM
dre2013's Avatar
pretty good cam from what ive seen. 112lsa will have your power in the upper rpm's, whereas the 114 will push it down lower. it would make a good DD cam imo, i am looking at a tsp 233/239 for a daily though
Old Sep 2, 2008 | 08:32 PM
teke184's Avatar
its on the upper range of the mild cams.
very good realiability and driveability with the proper tune.
thinking about it, i was under the impression that the higher the LSA (112 or 114) the higher in the rpm band the power usually peaked.
Old Sep 3, 2008 | 01:33 AM
Thanks a lot any idea of how much it would cost me to have it installed? I'm not capable of a job like that.
Old Sep 3, 2008 | 10:28 AM
teke184's Avatar
not sure but i would think about $1000
you have to remove most of the front engine accessories, and swap springs. then you'll need a dyno tune which can run upwards of $500
although a street tune is sometimes just as good if not better for part throttle.
parts you'll need for the swap are gonna be the cam, springs, pushrods, timing chain, and oil pump and the associated gaskets.
vendors sell the install kits for a good price.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
