which throttle body gasket
Old Jun 30, 2008 | 07:12 AM
knute_gis's Avatar
I have a Professional Products 85mm Throttle body and a BBK intake.
One came with a gasket that that covers up that little whole where the IAC is.
One does not(it has an openning from the throttle body to the intake), this is the one I used.
I'm having idle problems, should I have used the one that blocked this whole?
I have a LS6 with NO emissions.
Old Jun 30, 2008 | 10:31 AM
WhiteHawk's Avatar
I can't imagine that blocking the IAC passage would help the idle, so there must be something else going on causing your bad idle. Did you change anything other than the intake?
-Geoff
Old Jun 30, 2008 | 12:31 PM
knute_gis's Avatar
Its a swap into a 1997 gmc so I'm just trying to work out the bugs...
Just thought of this, but I don't thing its the problem.
thanks
HectorM52
Jul 30, 2017 11:46 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Fatdog2
Feb 13, 2015 08:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
