98 => on LS1 Ttemperature Gage
Old Sep 6, 2008 | 08:33 AM
NukeFPE's Avatar
Everyone knows the problem with the 98 to 02 water temperature gages "sitting" at 210F. Did anyone ever figure what needs to be changed out to make it a "real" working accurate gage like the earlier Camaro's?
Can you change the gage? sending unit? or is in in the ECM? or a combination thereof?
Old Sep 6, 2008 | 12:32 PM
2001NBMZ28's Avatar
Not that I know of, lots of people just install an aftermarket gauge. The '98 3 wire sensor/gauge was the last year they were accurate.
Old Sep 8, 2008 | 06:44 AM
AL SS590 M6's Avatar
Moderator
98 wt gages are accurate. 99-02s aren't and there's no way to fix the factory stuff to correct the problem. The gage sends the info to the PCM then it goes to the gage. No way has been found to modify the signal.
Most just put aftermarket wt gages in.
Old Sep 13, 2008 | 08:07 AM
fxgs's Avatar
Ecklers Camaro, www.ecklerscamaro.com, sells Autometer gauges (fuel, oil pressure, volt & water temp) that replace your in dash ones.
The ad says they will fit with "slight modification." Wonder what the slight modification is?
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Z Power
Sep 19, 2015 11:19 PM
