LS1 Camaro heater core hoses? Where? What?
The dealer doesnt carry the set anymore. Autozones are wrong, just a molded
angle (too short also), Kragen I would assume is the same, NAPA shows some
long hose (42") with an "L" at the end? It also shows just one hose for both of
the hoses, but they are two different diameters. The stock hose does a double
bend to go around a bracket and away from the exhaust. What are you guys
doing about this? I guess I can search through all the hoses that Autozone has
and possibly find ones that can be cut to fit. If someone did this already, share
what you found.
I found the two upper hose sections : WP to PS cooler, and PS cooler to the
radiator. That was unavailable from Autozone, but I found perfect replacements.
I will post the PN's later .. when I get home.
Tom
what you found.
Tom
Nah, I went through all the molded hoses and nothing is molded like the LS1.
I cut the ones on my LT1 and put the simple angle on. The LS1 goes out to
the fender, bends toward the front, bends again to the fender, got around a
bracket attached to the inner fender, then runs down the inner fender to the
aluminum hoses like the LT1. Its a crazy molded hose.
Tom
Tom
07-04-2005 05:00 PM
