2000
2000
i have a new crate motor. dyno was 405 horse 425 torque.i put 3:73 gears in a raptor tranny and a 2000 stall.i have a comp cam 268 and 29 inch tires and air shocks for clearance reasons.i am wondering why i cant break the tires loose from a stop,the only thing i can think of is the low stall.any ideas?
What were you thinking? With that motor you should have at least a 3200 and that's a bare minimum. It would be way happier with a 3800 or so.
What gears do you have with those 29s. Should be 4.10s if you want an kind of performance.
Get a 9.5" 4000rpm stall and 26" slicks/drag radials and run 11s.
Your combo is completely out of wack.
68camaroboltz
Oct 5, 2015 11:56 PM
