Different Backfire issue
Old Jun 11, 2008 | 05:05 PM
f1rob's Avatar
HELP! Different Backfire issue, Dealer not helping!
I have a totally stock(with the exception of a K&N air filter) 2000 SS LS1 with a 6-speed. The car has 50K miles on it. The car is typically only driven from June to September, and the rest of the year sits in the garage, where I start it and run it for about 10-15mins once a week.
Last year a "problem" started where it would let out a small backfire through the exhaust when the engine was reving down either when I upshifted, or downshifted. More specifically, if I downshifted, say, from 3rd to 2nd and the revs were above 2200rpm it would let out a few pronounced pops out the back. As soon as the revs dropped to 2200prm, the engine was smoother, and the backfire or popping was completely gone.
When I upshift through the gears, it also happens if I shift above the 2200rpm mark, and in both cases it's more pronounced, the higher the revs are.
This condition also seems to be more pronounced when the car is still warming up.
I took the car to the local Chevy dealer last year, took him for a test drive, and he told me "it's normal for these cars", but it was not hapenning before, so I have a hard time accepting this. Is it a timing thing? Like I said, nothing on the car has been altered, no check engine light. I'm leary about a lot of the local dealers, as they all just seem to want to gouge as many $$ as they can from me, and then have no solution.
Sorry for being so wordy, but any suggestions out there?
Last edited by f1rob; Jun 12, 2008 at 04:44 PM. Reason: Incomplete description in title
Old Jun 12, 2008 | 08:15 AM
AL SS590 M6's Avatar
Moderator
It is very normal for manual trans LS1s to pop thru the exhaust on decel especially when cold. Maybe your exhaust is a little louder due to age and now you're noticing it more.
Old Jun 12, 2008 | 11:08 AM
f1rob's Avatar
Thanks Al. Yeah, I considered that as well. The exhaust is the SLP stainless set up. Like I said, often times it is more than just a pop, and it does occur on decell, when warm as well, and also on upshift.
I forgot to mention that the fuel economy has dropped as well. I used to get approx 400kms on a tank city/hwy, and now it's about 340-350 kms. And just like most people, when a suspected problem surfaces, I think it's a little down on power as well.
I'm fishing now, but any suggestions are appreciated.
Old Jun 17, 2008 | 12:15 PM
f1rob's Avatar
Help folks!
Are there any other suggestions out there?
Chet1185
May 10, 2015 09:24 AM
Drtryder
Apr 22, 2015 04:17 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
F(ast)-body
Feb 26, 2003 09:05 AM
BAD BLACK WS6
Classic Engine Tech
Jun 8, 2002 02:06 PM
