Problems taking off
Problems taking off
My car is having major problems taking off. If I'm at a stop light and try to take off any faster than a snail, it seem like its flooding and will not do much for a second or two. If I'm on a hill at a light or sign it does the same thing, acts like its going to backfire but never does, if you floor it it gets worse so i just try to get out on the road before somebody behind me hits me. If its in neutral and I rev it, no problems, and it pulls great at anything above 2200 or so. Any ideas? i check for vacuum leaks, changed plugs, wires all looked good ( not very old, possibly 10,000 miles on them). I had a small leak where the headers meet the ory but i have that patched up now. No codes are being thrown. Its a 6 speed, F14 cam with this and that on it as well, nothing else major ever put on it, Nitrous SC, Turbos, nothing like that. I havnt been able to take it back the the gentleman that tuned it due to work schedule and the distance i have to drive it to do so. He said it might be the powerban of the cam, but i HIGHLY doubt that. I don't think he understands what its doing. Any ideas on what to look for?
Fuel filter was changed last oil change, which was about 2k ago, or 3 months ago or so. Havent checked the fuel pressure, didnt think that would be a problem since it was only down low where im having the issue, but i will get a gauge from a body and check it. Several tanks of gas have been ran through it. this issue started about 8 months ago.
Hesitation like that is usually in the tune. Did it run fine on the tune before? You need more airflow at tip-in. Sometimes if it is idling in open loop and driving in closed loop you get that blip in the transition.
-Geoff
-Geoff
Darth Xed
Jul 1, 2002 03:22 PM
