Vacume leak at iac valve
Old Nov 15, 2008 | 04:25 PM
Jachin99's Avatar
to make a long story short i have a vacume leak at my iac valve on my 99 z28 which i found by spraying it with some starting fluid. i inspected around an removed the valve and noticed that it didnt have an o ring or a gasket on it. is there supposed to be one there and if not how would i fix the leak. Its causing a check engine light to come on, which i have confirmed in another thread.
Old Nov 16, 2008 | 07:35 AM
AL SS590 M6's Avatar
Moderator
YEP it should have some sort of seal. IIRC it should have an Oring.
Old Nov 17, 2008 | 10:41 AM
2001NBMZ28's Avatar
Looked it up in my Helms, it should have an o ring.
Old Nov 17, 2008 | 11:43 AM
Jachin99's Avatar
Does anybody know if it is a special one or if i can just go and get one that seems like it fits at autozone
Old Nov 17, 2008 | 12:12 PM
2001NBMZ28's Avatar
I'd try autozone, don't think there's anything special about them. They probably won't know the size though so I'd bring it with me. Other option is visit the dealership, can't cost much either way.
Old Nov 17, 2008 | 09:56 PM
Jachin99's Avatar
Tried autozone, all they had was were the pack-o-o-rings garbage. i bought them anyway tried em and none fit. ill just say screw it and get it from the dealership.
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Amshnock
14
Jan 18, 2015 11:47 AM
blac94Z
Nov 28, 2014 01:53 PM
