last spark plug p/s
Old Jun 21, 2008 | 01:37 PM
TJ Chapman's Avatar
last spark plug p/s
i cannot get the last spark on the passenger side out!!! it seems impossible to get at. both up top and underneath. what has anyone else done?? help!! lol
Old Jun 21, 2008 | 03:05 PM
Z28luvr's Avatar
What I do is I unbolt the pipe from the manifold to the check valve and move it out of the way....then I just force my arm down there to get to the plug, but I do have small arms. You can also take the coil packs off that side. Just make sure to disconnect your battery first. To put the new plug in, I get about a 4" piece of 5/8" fuel line to put on the plug. That helps out a lot.
Old Jun 21, 2008 | 05:53 PM
angel71rs's Avatar
Ideas here: http://web.camaross.com/forums/showthread.php?t=609004
Old Jun 22, 2008 | 11:57 AM
TJ Chapman's Avatar
haha! i conquered the b@st@rd! this is a very useful technique for your future attempts. go underneath (at least i did) slide the sparkplug socket on, the put a deepwell 3/8 drive 3/4" socket on a 3/8 ratchet (i used a 12" long flex head)and from up top put the socket over the sparkplug socket (they have a 3/4" hex on the end of them usually for a wrench) and turn away it clears the manifold for a good swing but is short enough to fit inside the body. the only thing i had to remove was the A.I.R. tube (two 10mm bolts from exhaust manifold and a plastic clip on other end) BTW i had one person underneath and myself above to guid things along as smothly as possible but not sure that its a neccessity
Old Jun 24, 2008 | 07:04 AM
Capn Pete's Avatar
Rookie!!!
#8 is almost entirely done from underneath --- 1 person job!
You (obviously) have to get all the plug wires from up top (where they connect to the coils) EXCEPT #8 ... you access that plug from underneath. The ONLY "problem" I've found with that is that I have to use my LEFT arm ... actually, a lot of the work on the passenger's side requires using my left, vs. normally I would work with my right arm .
But you got it done ... good job .
Old Jun 24, 2008 | 09:07 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by Capn Pete
Rookie!!!
Don't know how on earth you reach 8 from below. I can't even begin to get my arm up thru to reach the plug.
Old Jun 24, 2008 | 07:00 PM
GnarlyZ28's Avatar
I do them all from the top, used this method: http://www.installuniversity.com/ins...sity/index.htm
Only thing not stated in the write up is that i used a universal joint style extension, especially on the #8 plug. Can get them done in about 1.5 hours this way, but i've done it about 4 times though
Old Jun 25, 2008 | 07:48 AM
Capn Pete's Avatar
Well, like I said, I'm using my "wrong" arm (left vs. right ....... at least, I'm pretty sure I can't reach up there with my right arm!? ... I think the angle ends up being all wrong that way???) which makes it a little awkward, and I don't exactly have "body builder arms", so maybe a bigger guy would have more trouble?!
FWIW, I've done it the same way with both the factory exhaust, AND with LT headers.
Old Jun 25, 2008 | 07:52 AM
Moderator
And I've tried it with factory exhaust and longtubes and with my left arm, won't fit.
Old Jun 25, 2008 | 08:14 AM
Z28luvr's Avatar
Me neither...especially if one still has the stock exhaust
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
