Trans Am Intake
Old Oct 3, 2008 | 10:21 AM
deerslayinrenek's Avatar
Trans Am Intake
What could be done to get more air into a 2000 T/A with ram air. I see these SLP Lids, are they for ram air cars. Does anyone make a better filter for them. Thanks guys
Old Oct 3, 2008 | 12:50 PM
slomarao's Avatar
you need a SSRA or FTRA. Check out ls1speed.com under the induction section. You will find them both, lids, KN filters, etc.
Old Oct 3, 2008 | 01:19 PM
Marc 85Z28's Avatar
The lid you refer to fits all 98-02 V8 cars, regardless of options. It should be your first power improving mod. If you still want/need more air in, consider a ported throttle body next and then an LS6 intake manifold, which can be found on all LS6 Corvettes and CTS-Vs, and all 2001 and later LS1s.
The stock MAF and intake tubing (bellows) is fine for most stock displacement combinations.
Several companies make high flow filters, but a quality paper filter is not going to hurt power.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
