Is this the correct way to measure lifter preload?
Old Aug 27, 2008 | 02:44 PM
Mike96z's Avatar
I have used the information ive found to calculate my lifter preload but to be sure ima use a pushrod length checker after I get it all together. Here is what I have calculated it as being.
7.380 Stock Pushrod
0.025 LS6 Cam Base Circle Diff
-0.060 LS7 Lifter cup is .060 shallower (FIXED)
7.345 My Pushrod Size
0.080 Plus Preload
7.425 Total Pushrod Length
Isnt adding the preload to the pushrod size correct?
Old Aug 27, 2008 | 03:42 PM
BUBBA's Avatar
I don't believe you would add the preload amount. Usually, as far as correct geometry would go, you'd use a pr checker and a solid lifter and check the geometry, going with the adjusted length as the correct pr.
I may be wrong.
Old Aug 27, 2008 | 03:59 PM
Mike96z's Avatar
well then if i had the 7.350 pushrod, the lifter would have no preload and would be really noisey and loose if im correct
Old Aug 28, 2008 | 07:02 AM
AL SS590 M6's Avatar
Moderator
You want to add 1/2 of the lifters total travel that way you're operating it in the middle of it's working range.
If the lifters total travel is .160'' then .080'' is right.
Old Aug 28, 2008 | 09:14 AM
Mike96z's Avatar
well gm recommends .080 - .100 preload
Old Aug 30, 2008 | 07:41 PM
Zitty'sZ's Avatar
7.380 Stock Pushrod
0.080 Plus Preload
If the base circle of the ls6 cam is .025 larger than the ls1 cam then your calculations look about right .
Old Sep 1, 2008 | 03:08 PM
DaddySS's Avatar
After you measure with the checker, add .080 to .100 and that's your pushrod length.
9t4lt4z28
Oct 2, 2015 10:28 AM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
