Thinking of 5.3 LS swap.....
Old Jun 4, 2008 | 03:06 PM
reamo04's Avatar
so, been looking into doing a 5.3 LS swap into my 94 LT1.
I will be keeping my turbo setup with whichever route i go, but the 5.3 seems to have about the same potential of a LS1 without the cost (can get the motor, computer, and trans for 1500).
Just wondering what you guys think, and what would all need done?
I know it'd need a new k-member, thinking maybe a BMR tubular, and then i would need a new trans, got that covered with a TH400
Old Jun 5, 2008 | 08:11 AM
teke184's Avatar
whats the compression on the 5.3L??
i know by swapping 5.3L heads onto a 5.7L ls1 you boost compression. would be something to look at. unless you intend to rebuild with blower pistons or new heads anyway.
Old Jun 5, 2008 | 04:02 PM
reamo04's Avatar
plan on rebuilding it anyways with new heads, cam, forged internals, everything.
Old Jun 7, 2008 | 06:15 AM
Capn Pete's Avatar
Get the UMI K-member. Seriously, check out the difference in the two. The UMI is much stronger.
As for the engine?? No reason not to do it. Assuming you're grabbing a 5.3 from a truck? The only big difference I can think of off hand is it's an iron block vs. the LS1's aluminum block. But that's ok, esp. considering you're boosting the engine . And obviously if you're building up the rotating assembly, you'll put lower comp. pistons in, to go with the turbo?
Sounds like a good plan to me ..... you're only sacrificing ~20 cu.in. ..... the 5.3's are great motors to begin with .
Old Jun 7, 2008 | 09:56 AM
reamo04's Avatar
yeah, Jim Parish put a 5.3L in a fairmont into the low 7's in the 1/8 on a completely stock longblock, and then was having problems with the turbo, and that was with a smaller turbo than i will be using.
So, it has good potential, especially if i throw on some L92 heads, zo6 cam, LS6 intake manifold, i'll be good to go
Old Jun 8, 2008 | 08:32 AM
AL SS590 M6's Avatar
Moderator
You can't use L92 heads with less than a 4'' bore and you can't use an LS6 intake with L92 heads.
Old Jun 8, 2008 | 11:56 AM
reamo04's Avatar
ahhhh, okay.
I know nothing about anything LS lol.
Anyways, i found a 5.3 locally that i will be picking up.
He also has 317? heads with it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
kandied91z
Mar 3, 2015 11:34 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
