2000 SS M6 -- Duhh: Where is the PCV?
Old Jun 25, 2008 | 10:26 AM
wrnchbndr's Avatar
At the front of the engine and part of the intake manifold right behind the throttle body on the passeger side is a hose connection. The rubber hose connected here is about four inches long. Pulling off the section of rubber hose reveals an inline fitting that look like a PCV valve end but the rest of this metal contraption is covered in an insulating rubber There is also what seems to be a ground wire connected to this. About three inches further the hose becomes a rigid plastic tube. Is this my PCV? And, does it just pull off of the rigid plastic tube? -- I don't want to break anything. I have the dreaded LS1 high oil consuption with no puddle and no smoke. I want to change the PCV and install a catch can.
Old Jun 25, 2008 | 04:31 PM
super83Z's Avatar
Whatever you described that looks like a PCV valve is it. Just pull it out.
Old Jun 25, 2008 | 10:28 PM
Red89GTA's Avatar
Pictures? show us what you are talking about, it'll make it an easier diag, but what it sounds like is the pcv. Put a breather there and smile.
Old Jun 26, 2008 | 06:40 AM
AL SS590 M6's Avatar
Moderator
Yep that's the PCV valve. The ground wire clips around the body of the valve and the valve just pulls out of the insulation and tube that it's plugged into.
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
68camaroboltz
Oct 5, 2015 11:56 PM
drt
Sep 27, 2015 04:39 PM
pepon214tx
Sep 20, 2015 04:48 PM
scottcba1
Sep 8, 2015 09:52 AM
