Synthetic ATF?
I noticed the local auto parts store sells things like Mobile 1 synthetic ATF and B&M Trickshift fluid. I was wondering would this stuff be worth the switch? I have a new tranny pan on the way and of course I will have to change my fluid when I get it so I was looking to make an upgrade. Is synthetic ATF worth the extra money?
Re: Synthetic ATF?
From what I have read its not good for the tranny to switch to Synthetic. I thought about doing it too. Sometimes changing the tranny fluid on higher mileage transmissions can be fatal for it. I'd stay stick with regular fluid from what I understand.
-Dustin-
-Dustin-
Re: Synthetic ATF?
At around 68k. Just changed it last week and the stuff looks brand new at 80k. You should be fine unless you are currently having tranny problems now.
I did notice that you said your tranny pan is on the way so that must mean you have an A4. Not sure how much fluid goes in an A4 but I know it's alot more than 4qts. And I'm pretty sure it's not good to mix synthetic with regular Dexron Mercon III. It's up to how much $ you want to spend.
Re: Synthetic ATF?
Re: Synthetic ATF?
Originally Posted by Cerwin Vega Fan
See that is the problem, even if pull the pan their still will be fluid left in the converter and I really don't feel like pulling the converter just for some tranny fluid.
Not sure how differently M6's react to syn. compared to A4's.
-Dustin-
Re: Synthetic ATF?
Originally Posted by Bersaglieri
Get a new stall
-Dustin-
-Dustin-
psychocabbage
Sep 7, 2002 09:33 AM
