Gear swap ???s
Old Apr 24, 2005 | 04:09 PM
jst's Avatar
jst
Gear swap ???s
I recently purchased a 95 Z28 with 80,000 mile.The only thing done to it is th owner had the muffler replaced witha straight pipe.My questions are,I am changing to a 3.73 rear and am curios of the difference in acceleration and 1/4 mile.What type of effect will this have on my in town/highway driving?What will this do to my gas milage?The car is also a A4.thanks.
Old Apr 24, 2005 | 11:07 PM
blackztpi's Avatar
Re: Gear swap ???s
assuming your car has 2.73's, it will change the acceleration of the car drastically, but you will lost some top end (so what). its completely worth it. you will lose some gas mileage in town, but you will see most of your drop on highway crusies. the a4 overdrive is only .70, so if you will run a significant number higher rpm on the highway. for cars without 11 second timeslips, 3.42's seem to be a good choice. you dont lose as much top end, and it will still be a vast improvement from 2.73's. if you have 3.23's (varified by a "1" on the shifter plate below the "2") and you are unhapy with them, you might want to go with 3.73's. personally, i like gas mileage, and it's not worth it to go to 3.73's over 3.42's on a bolt on A4 car IMO.
Old Apr 25, 2005 | 08:24 PM
jst's Avatar
jst
Re: Gear swap ???s
How much of a e.t. reduction can be expected with the gear swap,cai, and catback?Would 4.10s be overkill on the A4 car?
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
