Ok, I need to make some plans for my converter install..
Old Apr 29, 2005 | 12:43 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
In another thread... thats dead now... i was told 01-02 models need computer work to adjust to a stall converter properly...
I'm probably going to end up doing this myself with a friend or two in connecticut (i've done it before, but still am not looking forward to it, mainly because of the cooler lines and top 2 block bolts)
I'll have a shop install the transmission cooler for me.
ANYWAYS, what I need to know... what exactly do i need done to my computer? and what does the place that does it need? (someone mentioned you have to have a dyno or something )
I need to know specifically what i need and what to ask for so i can find a place that can do it, and make all the arrangements so i can get it tuned the same day/next day after the install.
I apreciate it
Jared
Old Apr 29, 2005 | 02:06 PM
1SlowFormula's Avatar
Re: Ok, I need to make some plans for my converter install..
It has been a while since I have read about this, but I believe the thing those years need done is either removal, or lessening of the Torque Managment program in the PCM.. I think if the shop had tuning software for the LS1 then it should be good, I think when someone mentioned the dyno it was to see the effects of the Torque Managment, and if their adjustment of the settings in the PCM were geting it done.
I believe if you have HP tuner or something similar then you can probably do it yourself or at least get a good tuner to do it for you..
Old Apr 29, 2005 | 02:18 PM
frmula1's Avatar
so thats it?
delete torque management?
no change of shift points? etc?
Old Apr 29, 2005 | 02:42 PM
Mine is a 95 so to be honest I read those threads just to get a little more knowledge, I have never done it myself.. But yes I think this is all that needs to be done that is different then installing a converter in other years.. That is with the exception of OBD-I cars may need other computer tweaks if the stalll speed is above 3K.
Old Apr 29, 2005 | 03:22 PM
2001NBMZ28's Avatar
After my TC install I experienced some "idle hunting" at slow speeds when coming to a stoplight/in parking lots - sometimes the car would even die. I got an email tune from RWTD - he increased my in gear idle about 150 RPM, shift firmness (no shift kit), and completely deleted TM. I played with my shift points a little on my own but didn't see much difference so I'm running the stock settings now, can't afford dyno tuning - but that's the way to go. I'd wait a few days before getting it tuned to allow the PCM to do some relearning first. Just my experience, hope this helps...
Old Apr 29, 2005 | 03:33 PM
frmula1's Avatar
ok.. an e-mail tune
how does that work?
what will I need? like as far as hardware and stuff to get it into my pcm?
Old Apr 29, 2005 | 04:13 PM
2001NBMZ28's Avatar
I already had a Predator, so that's the route I went for a tune. If you're going to get a dyno tune you shouldn't need to bring anything but your car - they'll have the necessary hardware/software to make you a tune.
Old Apr 29, 2005 | 04:27 PM
frmula1's Avatar
i dunno if i wanna spend the money on a dyno tune tho...
how much of a gain will it get me hp wise... not having to do with the adjustments for the stall converter?
can a basically stock engine car gain any decent hp from a dyno tune?
if not... i'd rather just get the cheapest tune possible to make my stall work the best way it can
DirtyDaveW
Dec 1, 2016 05:37 PM
ChrisFrez
Feb 15, 2015 07:49 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
joe777107
Dec 1, 2014 09:32 AM
