how to remove pressure plate bolts??
Old Apr 29, 2005 | 07:11 PM
teke184's Avatar
got the trans out, bellhousing off...now i got 2 questions
how do i secure the clutch so that it doesn't spin when i try to remove the bolts for the PP? same goes for torquing them down?
and second...how is the slave cyliinder removed. it's hanging by a hose. doesn't look like it's got a fitting.
i didn't look too hard since it was getting dark. just figured i'd ask prior to getting under it in the AM.
thanks
anyone know the torque specs for the FW, PP and all those other bolts?
Old Apr 29, 2005 | 10:28 PM
OBE1 95Z28's Avatar
Re: how to remove pressure plate bolts??
If you're replacing the pressure plate, you can use an impact gun to remove the bolts. Be careful that once the bolts are loose the clutch disk can fall out the bottom. You can use the clutch installation tool to hold it in place until the bolts are removed. When installing the PP, you want to tighten the bolts in a "star" pattern and tighten them down a little at a time. You do this as the PP is spring loaded and you want it to clamp it down evenly. Final torque is approximately 25 ft-lbs. Have a buddy use a breaker bar and socket to keep the crank pulley (catch one of the 3 bolts) from rotating, this will hold the flywheel in place for you.
Old Apr 29, 2005 | 10:32 PM
OBE1 95Z28's Avatar
GM sells the clutch master/slave/reservoir as an assembly; it evens comes with fluid installed. There are aftermarket slave cylinders that can be installed. There's a roll pin that separates the steel braided line/fitting from the slave cylinder body.
Old Apr 30, 2005 | 08:11 AM
teke184's Avatar
thanks guys
got the bolts no problem first thing this morning...
havn't tackled teh slave yet...so thanks for the tip.
anyone know how to remove the pilot bearing?? :sad:
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Jan 30, 2015 11:08 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
