pro 5.0 installation
Old Apr 18, 2005 | 05:26 PM
unvc92camarors's Avatar
hey, a few questions...
who here used a gasket like the guy on projecttransam.com? where and what part# is the gasket material you got?
and also, who just used rtv? do you notice any more vibration?
edit- how the heck did you get the **** off?
i am by no means a weak guy but this thing is stuck on there!
it is an aftermarket pistol grip (put in by the previous owner) but it is really really stuck
any ideas?
Old Apr 18, 2005 | 10:10 PM
OBE1 95Z28's Avatar
Re: pro 5.0 installation
I'm using a gasket. Auto parts stores sell paper gasket material in a sheet and you just cut it to fit. The real advantage is that if you pull your tranny often, you don't have to scrap off the old RTV. The gasket also might help to reduce vibration noises.
Old Apr 18, 2005 | 10:44 PM
o ok, i might stop by advance tomorrow and get a gasket then
and yea, i'm trying to reduce on vibrations in my car
got to keep it somewhat quiet for the ladies
and how hard did you have to twist to get off the ****?
i pulled as hard as i could and it would only move maybe an inch to the left
i'm not too worried about breaking it but it seems like it's twisting the stick as well
Old Apr 18, 2005 | 10:59 PM
BMJ's Avatar
BMJ
i dont know if this is what ur looking for but this helped me out when i install it, the guy does a awsome job walking threw
http://ls1howto.com/index.php?article=12
Old Apr 19, 2005 | 09:36 AM
OBE1 95Z28's Avatar
**** unscrews, it doesn't pull off.
Old Apr 19, 2005 | 12:05 PM
yea i know that, but i'm twisting with all my might and the damn thing won't come off
it's definately a gut check in masulinity i guess
Old Apr 19, 2005 | 03:11 PM
346CItofreedom's Avatar
Question Re: pro 5.0 installation
How hard does it vibrate for you guys that used the RTV? I know there's only seven inches of metal between your hand and crap thats spinning at 6000 rpm, but it shakes a little hard! One of my friends said her arm almost went numb from it, hahah!
Old Apr 20, 2005 | 12:52 PM
CreatiVe2's Avatar
its really not supposed to viberate all that much, i used a rubber gasket just to cut down on noise, and it does a great job!
Old Apr 20, 2005 | 04:08 PM
Ken S's Avatar
sure your screwing the right way?
If I remember there's a bit of glue in it.. once you overcome that, it comes off pretty easily... some people have had harder times than others.
I used RTV.. vibrates a little more than stock(especially since there are no rubber bushings anywhere), but not anything crazy.. Might want to check your trans mount.
Old Apr 20, 2005 | 05:17 PM
well it is an aftermarket shift **** so i'm thinking the previous owner just put gobs of rtv on it
i'm actually just gonna get the 2 bolts off of the shifter and pull the whole stick out
i won't be re-using the ****, i'm using stock now
thanks for the help guys
Old Aug 4, 2005 | 08:03 AM
Fujimo's Avatar
An easy way to remove the shift ****, is to wrap a towel around it and take some big channel locks to it and twist it off
Old Aug 6, 2005 | 10:48 AM
skisax80's Avatar
i used RTV.. vibration isnt too bad.. could be better, but its by no means a distraction or anything. i am however having some trouble with heat and im asking around on the boards to get help with that.
Old Aug 6, 2005 | 11:10 AM
MTL_Z28's Avatar
On that install guide he says to remove the stop bolts, that's the first time I've seen that. I thought they were pretty important? Does anyone else recommend taking them off?
Old Aug 6, 2005 | 01:26 PM
The stock doesn't have them nor but a few of aftermarket ones. I use them. If installed right, they have no effect on the shifter but they will come in handy incase you throw it too hard so it won't bend the shift forks.
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
