Question on 9 inch
Old Apr 28, 2005 | 09:26 PM
wicked_95z's Avatar
Question on 9 inch
I have seen that in the group purchase section that 98 and newer have to send in their brakebacking plates to get the bearing pressed on( I think). Anyway do I have to worry about this with my 95. How are the axles held into place. My rear is showing up tommorow and Ijust wanted to get a heads up on assembling it. Thanks
Old Apr 28, 2005 | 09:47 PM
1BAD86Z's Avatar
Re: Question on 9 inch
I'll let this one simmer for a couple of days.
Old Apr 28, 2005 | 10:04 PM
94formulabz's Avatar
Short answer: Yes, you need to take your backing plates off your 10 bolt before you get the bearing pressed onto the axles.
Your 10 bolt, just like the 98 up, has c clips which go on the tip of the axle to retain them inside the spider gears in the differential. This is why if you see a stock fbody break an axle at the track the wheel will 'walk' out of the housing.
With a c clip eliminator kit (included / stock on the moser 9") the wheel bearing is attached securely to the axle instead of the housing. A fundemental part of this design is that the wheel bearing must be pressed on over the brake mounting plate. When the plate is bolted onto the end of the housing it then holds the bearing which holds the axle in place.
I see the potential for another moser shim debacle......
Read this thread in its entirety
http://web.camaross.com/forums/showt...highlight=shim
Hit me up on IM if you need some more explanation.
-brent
Old Apr 28, 2005 | 10:26 PM
1BAD86Z's Avatar
What about the wedding ring?
Old Apr 28, 2005 | 10:36 PM
Hey, you ever even installed a Moser? They can be a bitch for first timers. I don't know about you but i'm on this site to share knowledge and help others out. He was unsure about something and asked a question, i answered, thats the whole freaking point of this site.
-brent
Old Apr 28, 2005 | 10:51 PM
1BAD86Z's Avatar
-brent
He purchased the axle from me, I just wanted to see if anyone else knew.
Don't get cocky, I'm a licenced axle mexhanic and I have worked at AAM for the past 5.5 years cutting gears for the 8.6 in chevrolet trucks. And yes I have installed about 9 so far.
My shop www.driveline-solutions.com
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TitoPR221
Jan 2, 2015 03:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
ChameleonGreen
Sep 2, 2002 05:15 AM
Brad 97z
Aug 10, 2002 09:58 AM
