Transmission Pan bolts??
Re: Transmission Pan bolts??
UH OH...so is there anywhere I could pick up these special washer? Mine has been back together for a couple months just straight bolts but it hasn't been driven much. Might be leaking, I'm not really sure. Thanks!
The washers keep you from bending the pan up. The washers are concave, facing the thread end. If you screw them down too much, the washer flips the other way. In that case, you are supposed to replace them. I believe the washer is part of the stock bolt. If you are surviving without leaks, I wouldn't worry too much about it.
Cool, I will keep a close eye on it. The problem is that I actually spilt a bit of trans fluid and I need to clean it all up off the bottom side so I can distinguish a leak from a drop.
stockssn2o
May 25, 2015 08:54 AM
