are all 4L60E's the same?
Old Apr 23, 2005 | 08:10 PM
Haskin Z28's Avatar
i bought a used 4L60E for 60 bucks from a 93 sonoma..just curious..will this work on my 95 trans am..im doing heads/cam converter and i wanna put a big converter in my tranny..but i wanna make sure i can use this one as a spare
Old Apr 23, 2005 | 08:17 PM
madwolf's Avatar
Re: are all 4L60E's the same?
F-body 94 4L60Es are different from 95-97 because it didn't have PWM.
LS1 F-body 4L60Es will not work in an LT1 car.
Corvette 4L60Es are completely different.
Not sure if the Sonoma one will work. Are you sure it's not a 4L60? 93 F-bodies had 4L60s in 93.
Old Apr 24, 2005 | 12:20 AM
hallbilly's Avatar
would the gear ratio's be the same then??
Old Apr 24, 2005 | 08:45 AM
OldSStroker's Avatar
Gear ratios are the same: 3.06; 1.63; 1.00; .70.
The internals, like clutch packs, pressure, and a few other things are built for the specific engine/vehicle combination. You can have the trans rebuilt to F-body or Vette specs or even stronger. That's probably a good deal.
Sonoma/S10 4.3L V6 trans has same flywheel housing bolt pattern as SBC, but it doesn't have the capability to upshift into OD at wide open throttle. This can be fixed during the rebuild. Transmissions for the 2.8L/3.1L 60 degree V6 have a different bolt pattern.
IOW, if it's a 4.3L V6, two-wheel drive transmission, you have a good core.
Old Apr 24, 2005 | 09:46 AM
94zgreenmachine's Avatar
I thought 93's were 4L60. They were not electronically shifted or controlled by the PCM ,hence no "E" at the end of the 4L60.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
