New Clutch Sticks Like Old One
Old May 3, 2005 | 08:49 PM
Chris_Camaro's Avatar
i bought a New Spec Stage 1 clutch, it sticks when i try to drag off the line, and my old one did that just before i got a new one, but i still have that problem, i was told a few didferent things it could be, some spring, the hydraulic clutch fluid may need to be flushed, any ideas?
sticks like, the rpms going up, clutch is still engaged(i say that right?), somtimes the pedal takes a minute to come back up to normal height
Old May 3, 2005 | 09:13 PM
teke184's Avatar
Re: New Clutch Sticks Like Old One
could be the restriction in the hydrolic lines...
look up "drill mod"
Old May 3, 2005 | 11:00 PM
97TURBOSS's Avatar
did you lube the input shaft so that the throwout bearing can return smoothly? try flushing your clutch lines...if you dont know the proper way to do this, take it to a shop. good luck
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
SEOJustin
Sep 24, 2015 04:39 PM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
