Putting together a 12bolt, what else do i need?
Old Apr 24, 2005 | 07:22 AM
Valkyn71's Avatar
Working on piecing together a 12 bolt, heres what i have so far:
Eaton 12 bolt Posi, 30 spline
Moser Pro street 3.73 gears
bearings, races and all shims to install carrier and pinion gear.
Ratech solid pinion spacer
reluctor ring installed for ABS.
So if i bought one of these:
Moser F-Body 12 Bolt Housing & Axle Package
(Includes 12 Bolt Housing with brackets, M/E Custom Alloy Axles, new housing ends, wheel bearings, wheel studs, retainer plates)
Would i be good to go? Or whatelse would i need for a complete rear other than a pinion yoke?
Does the housing come with the hole for the ABS sensor on top of the pumpkin?
Old Apr 25, 2005 | 12:08 AM
blackztpi's Avatar
Re: Putting together a 12bolt, what else do i need?
I think you covered most of the parts you will need for the 12 bolt build, but remember to buy yourself some special tools. you will need an in. lb torque wrench for main bearing preload, a decent caliper, decent dial indicator, as well as a shim driver and a press for the bearings.
Old Apr 25, 2005 | 06:59 AM
Valkyn71's Avatar
I plan on taking it somewhere to have it "setup", so hopefully it wont come to me needed those tools. Would rather have someone with experience do it than try my hand at it for the first time on such an expensive rear.
Heathen1
Jan 2, 2016 04:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
tubby
Oct 13, 2003 09:16 AM
slocody
Feb 10, 2003 01:04 PM
