t 56 rebuild
Old Apr 27, 2005 | 12:03 PM
stmz28's Avatar
t 56 rebuild
Were is a good place to get a t 56 trans rebuilt better than stock.
Sean
Old Apr 27, 2005 | 10:04 PM
blackztpi's Avatar
Re: t 56 rebuild
D&D does nice jobs from what i hear. they sell some very nice parts at decent prices too, so if detriot is too far(i think thats where it's at), then you can always order the parts from them and have a local reputable builder build it with those parts in it. I'm sure a lot of people sell good t-56 parts, but D&D i know for sure does.
Old Apr 27, 2005 | 10:07 PM
blackztpi's Avatar
Re: t 56 rebuild
DDperformance.com
Old May 8, 2005 | 12:15 PM
93ZM6Tally's Avatar
Re: t 56 rebuild
In your garage with D&D parts.
Old May 9, 2005 | 08:15 AM
stmz28's Avatar
Re: t 56 rebuild
if you rebuild your trans should you buy the viper outup shaft. How much power is the shock one good for.
Old May 9, 2005 | 10:10 AM
93ZM6Tally's Avatar
Re: t 56 rebuild
I think the Viper output shaft maybe a little overkill. There are people holding some pretty serious power on stock shaft T56 trannies. The Viper shaft and housing is going to run you about $750. Don't get me wrong, it's a good upgrade but I don't think you'll need it with a properly prepped T56, (and clutch).
Old May 10, 2005 | 08:12 PM
ayalam's Avatar
Re: t 56 rebuild
how much for just labor of rebuilding usually cost i'll put it in myself?
Old May 13, 2005 | 10:00 AM
stmz28's Avatar
Re: t 56 rebuild
How hard is it to rebuild the trans your self do you need any specific tools and can you body do it.
Old May 13, 2005 | 06:07 PM
JDMZ28's Avatar
Re: t 56 rebuild
They can get pretty complicated. I had mine done at Liberty Gear, they specialize in manuals, they do all APE's transmissions, the guy I talked to was honest and straight forward. It all depends on how bad the trans is. I'm only paying 195 for labor to have it done right. I'm picking it up tomorrow for right around 800 total, I'm getting all new syncros, billet dogs, and a couple shafts.
Old May 14, 2005 | 06:49 PM
RedWS6TA's Avatar
Re: t 56 rebuild
www.jenningsengineering.net/
the only way to go!!!!
Old May 15, 2005 | 02:28 PM
93ZM6Tally's Avatar
Re: t 56 rebuild
It really isn't as bad as I thought. Basically you need a couple of pairs of good snap ring pliers, needle and flat type. A long puller, I modified a standard three jaw with 2 dollars worth of flat stock. Just a lot of parts, gears and snap rings. I used an install guide with pictures and the service manual. I took lots of pictures and it really wasn't as bad as I had thought. A hydraulic press would be a big help BTW, I got away without one, used two by fours and a weighted rubber mallet, but that's more of a pain. Great sense of accomplishment.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
