700R4 Planetaries?
Old Apr 23, 2005 | 08:48 PM
M93Z's Avatar
700R4 Planetaries?
Today I tore down my 700R4 trans and found [surprise] the 3 -4 clutches are burned along with the band. The end play on the front & rear planetary pinions is about .015 but when I spin the individual gears there are a couple that are noisy is this normal or should I just replace both planets?
Thanks.
Old Apr 24, 2005 | 04:14 AM
Pro Built Automatics's Avatar
Re: 700R4 Planetaries?
Make sure the gears are not hitting the encased bearing when checking these out, as the will create noise. If they make noise, or feel slightly rough, you might consider relacing them.
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
jimmybandana
Mar 22, 2015 07:44 PM
CaRParts102
Dec 6, 2014 08:45 AM
