stall question...
Old Apr 25, 2005 | 09:56 PM
1quickgt's Avatar
stall question...
getting a 2800 vigalantie from a freind going in my 94 t/a what tranny cooler should i use and anythiing els ei need before getting the install done...also what time shoudl i expect wiht my mods
cai
exhaust
as&m mids
cutout
stall
spotlines
blistines
Old Apr 25, 2005 | 11:27 PM
blackztpi's Avatar
Re: stall question...
about any quality trans cooler will work. about anything in your summit magazine, like a tci or something will be fine. 2800 doesn't make tremendous amounts of heat like a 4000 stall, so u don't need the most heavy duty cooler on the market, but you will probably spend about 50 bucks for a good one. as far as what you should run..... if you have 2.73's probably some kind of mid-higher 13 second run. if you have 3.23's (indicated by a "1" on the shifter plate under the "2") you can probably look for lower-mid 13's on good traction.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
