tranny probs need some advice Quick???
Old May 3, 2005 | 05:05 PM
hughett17's Avatar
ok...i have had my tranny build 3 times which was under waranty the whole time but i can drive it for a month then it will shift throuh the gears right and then its like i hit neutral and 1-2 is al it has from there i took it back to the shop and he said a performance valve body , bands and 3-4 clutches so im guessin my tranny wont take the power my motor has but the funny thing is that my car is stock and i was wondering if anyone knows what the best high performance parts listed above i should get or if any more things i need please list or what i should do to prevent it i am looking at tci parts but are they worth anything or am i just wasting my time ??????
Old May 3, 2005 | 05:42 PM
Birdman7389's Avatar
Re: tranny probs need some advice Quick???
1)This post should be in the drivetrain forum....
2)PLEASE try to add some sort of puntcuation or form to your post so we can read it easier.
3)Give us info! What year car? Auto trans I assume?
4)Sound to me like the shop you are using does not know what they are doing. Many places can rebuild a trans to stock levels with no problems.
Old May 4, 2005 | 06:17 AM
12SCNDZ's Avatar
It sounds like the 3-4 clutches are wasted. As for these transmissions not being able to "take the power"?...I've got them out there in cars running 11.0 @ 124 MPH.
Frank
Old May 4, 2005 | 07:55 AM
1SlowFormula's Avatar
as far as a good parts list check out the link in my sig.
Old May 5, 2005 | 06:46 PM
hughett17's Avatar
Thumbs up Re: tranny probs need some advice Quick???
well i really dint have time to do all punctuate and yes it is a auto sorry for the miss info the main thing going bad is the epc solenoid and the valve body and i dont have 3-4 clutches i am getting them to handle the power hopefully but i baught all new products from art carr and it should get the job done and my car is a 1994 z28 with the junky 4l60e trans but im sure you guys no that
Old May 5, 2005 | 09:52 PM
sir dyno's Avatar
If you have an automatic, then your tranny does have 3-4 clutches and as others have said you probably fried the 3-4 clutches which is 3rd and 4th gear -I may be wrong. I would think performance parts brand name or not would be a good improvement over regular performing parts. Good luck.
Old May 6, 2005 | 07:31 AM
This is both accurate and inaccurate at the same time...
Performance parts are almost always better, but just because you by something from a dealer that also sells performance items doesn't mean you are going to get the upgraded parts unless you specifically ask for them. And you just can’t buy some performance parts and expect the whole setup to work well together, it's like upgrading the cam to a large performance cam (like an LT1 w/ a cc306) and not touching the valve springs, it won't work well for long because it’s all about the right combination of parts…
OH just so you know, Art Car doesn't manufacture any of the clutches themselves; they use other manufacturers just like any other builder. The items you are buying from them could be bought anywhere, you are just paying more be cause the invoice says Art Carr…
*** EDIT ***
sir dyno - just so you know I was not directing this all to you, I just started with a quote of your last message to help prove my point, because you pretty much said the same thing.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
