What type of lube for pilot bushing?
I am in the process of installing a SPEC stage 2 clutch in my '96 Z28 right now. I bought the pilot bushing (solid brass piece) instead of the pilot bearing (little roller bearings). My question is do I just use a standard high-temp wheel bearing grease for the inside? Do I pack the lube in the small hole or just lightly coat the inside? Also, how much high-temp white lithium grease do I put on the splined input shaft of the transmission (T56). Thanks!
Jeff
Jeff
Re: What type of lube for pilot bushing?
The instructions for my bronze bushing said to use a light coat of oil only because grease would interfere with the self lubricating properties of the bushing.
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
