LT1, A4 to M6 questions
Old Apr 17, 2005 | 09:30 PM
ShawnLT4Z's Avatar
i have a 96 Z/28 4l60e. i am trying to do a t56 swap, but i am having trouble finding parts and i also have some questions.
i have the t56, clutch, pressure plate, throw-out bearing, and shifter. and i need everything else.
1. are ls1 and lt1 pedal assemblys interchangeable?
2. will an ls1 slave cyl work work with an lt1 clutch?
3. are the master clyinders different on a manual compared to an auto?
4. are the drive shafts interchangeable from a4 to m6?
5. is there anything is i should be aware of when attempting this swap?
sorry i have so many questions... but i am kinda stuck right now
Old Apr 17, 2005 | 11:14 PM
ShawnLT4Z's Avatar
Re: LT1, A4 to M6 questions
anyone?
Old Apr 17, 2005 | 11:47 PM
No. The LS1 slave cylinder bolts to the front cover of the tranny, concentric with the tranny input shaft, and is a conventional "push" design. Completely different than the LT1 slave that bolts to the bellhousing, and uses a fork for a "pull back" design.
Yes.
Old Apr 17, 2005 | 11:51 PM
ShawnLT4Z's Avatar
thanks!
Old Apr 18, 2005 | 12:10 PM
Cool ZR's Avatar
Check out this website. I am in the process of the doing the same myself
http://www.afrashteh.com/tranny_pics/T56.htm
I was told the pedals are the same right up to 02
Old Apr 18, 2005 | 12:42 PM
ShawnLT4Z's Avatar
ya... i use that website all the time. its very helpful
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
