a little help regarding slave cylinder
Old May 3, 2005 | 01:25 PM
J's ss's Avatar
simple question , master cylinder line
I have just finished replacing my clutch and putting it all back together. All is going well in life untill I try to put the master cylinder line back into the slave cylinder. I cant get the quick connect fitting back into the tranny. It does not apear to be damaged in anyway. I thought u just had to push it in and give it a small tug to make sure it is secure. It all fits just does not lock in. I realy dont want to go to the shop and tell them I got the transmision out in an hour but has taken me a day for somthing that seems so simple. A little confused any help would be appritiated thanks in advance.
__________________
2001 red camaro ss T-tops, M6, minor bolt-ons, K&N, SLP wisper lid, cold air induction kit, QTP electric cutout, spec 3 clutch
Hail to the LS1 bow down to the untouchables biaatch
we will slow down when we pass u so u can kiss our a$$
Old May 3, 2005 | 09:16 PM
teke184's Avatar
Re: a little help regarding slave cylinder
are the little metal "teeth" inside the fitting in good shape?
is the plastic ring out of the way?
i did mine 2 time this past weekend for my clutch install...it just snapped in to place.
Old May 19, 2005 | 03:20 PM
J's ss's Avatar
thanks man slave was bad,, the little plunger was broke how many tries does it take to bleed the system
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
