Is this flywheel usable?
Old Apr 27, 2005 | 12:31 AM
madwolf's Avatar
Picture is not dialup friendly ~ 900kb.
You can see it here. Should I attempt to have it resurfaced or it's not worth it?
Old Apr 27, 2005 | 03:30 AM
GreenDemon's Avatar
Re: Is this flywheel usable?
It looks OK to me. Just check for discoloration/blueing (overheating) and deep marks. As long as it can be refinished to a smooth surface and not be under the minimum diameter it should be fine. If you've got some tools to measure it you could make sure you're not wasting your time, although I don't think I've ever seen the spec on that, I'm sure a machine shop would though.
Old May 10, 2005 | 08:35 PM
ayalam's Avatar
what's the minimum diameter? I'm having problems with noise coming from the tranny there while in neutral. clutch has less than 1000 miles on it spec stage 2. just trying to figure out the problem.
Old May 10, 2005 | 08:41 PM
markinkc69z's Avatar
That's an aftermarket flywheel isn't it? The original dual mass flywheel was there to quiet those noises in your 6 speed.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
