transmission question
Re: transmission question
there are a few electronic controls that are different, but everything else inside is the same, if your electriniics are good and you know a little and can get in there to change it then yes it will work.
internal...
I need to double check but you may have to change the conector and the electronic controls on the valve body.. Let me look for the exact differences in those years...
The '97 is a PWM (Pulse Width Modulated) lock-up transmission... The '94 is not. The electrical hookups in the case are different also, and that would be the hardest part to change over.
All said and done I don't think this should be attempted...
