My Tranny is Squeeling (A4)
Old Apr 23, 2005 | 02:07 PM
WhiteThunderZ28's Avatar
My problem is that when I would take of from a light normally the tranny doesnt make any noise but at as soon as i hit 45mph+ its starts squeeling while giving it load but if I take my foot off the gas it will stop, give it load it will continue.
If I lauch hard it will squeel also, until i get off the gas or if Im under 45mph.
So just normal driving over 45mph with load on it squeels like a pig until i get off the gas.
Tranny fluid is full, not burnt... I have gotten my cartuned with firmer tranny shifts, could that be a problem?
Im thinking that it is my stock stall convertor going? What do you guys think?
Thanks, Josh
Old Apr 23, 2005 | 02:16 PM
BLinindoll's Avatar
Re: My Tranny is Squeeling (A4)
Could be the convertor. If it does it in more gears then one than it probably is. If your gonna pull the tranny, depending on the miles, you might just want to go ahead and do a rebuild while it's out. Save you from pulling it again when, or if, it decides to go on you.
BTW, the frimer shifts actually help the tranny. Instead of easing into the gear like normal, it grabs the gear, and doesn't let the clutch packs slip as much and wear out. Not sure the effects on the convertor though. I would think under normal driving it would be able to handle it. But then again, what's "normal."
Old Apr 23, 2005 | 02:19 PM
Thanks for the quick reply... Um the tranny has 57,xxx on it while the stocl stall has 178,000, so thranny has been replace by GM...Im also think that it might be the stall.
Old Apr 23, 2005 | 02:33 PM
BLinindoll's Avatar
Yeah, with that many miles for the convertor, that would probably be the answer. Man, I'm surprized they didn't put one in with the rebuild. Live and learn I guess. Also, forget about the rebuild. You should be fine on 57 something.
Old Apr 23, 2005 | 02:52 PM
Yeah Later in time i will replace the stall but right now Ion just sent me the de-tune for my tranny, now Ill see what happens... Thanks Ion aka MadZ28 Tuning
Old Apr 24, 2005 | 01:31 AM
Spinner's Avatar
GM replaces the stall with their new trans'. Could be your rearend?
Old Apr 24, 2005 | 10:37 AM
12SCNDZ's Avatar
Are you absolutely sure this isn't your serpentine belt making noise? F-Bodies are notorious for squeeling belts. Many times it's improperly diagnosed as a transmission problem. Most of the times it happens at higher RPM's (around shift points), but if you've got a tentioner going bad, it could cause a problem like you're explaining.
Frank
Old Apr 27, 2005 | 01:27 AM
1FstFormulaV8's Avatar
Mine squeeled just like you described then she finally snapped. I'de get it checked out ASAP.
Old Apr 27, 2005 | 01:30 AM
Well I checked my tensioner out and it seemed fine but my alternator had a little squeeking when I spun it so maybe the alternator is going (bearing wise).
The tranny shifts perfectly but Ill let you know how tomarro goes.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
