No 3->4 shift
In fact; I think it's stuck in 3rd. It has no low end power like it use to. I can shift it manually though into 3rd but not 4th. Manual shift gives crisp shifts. I can not fill it shifting with the selector in OD.
In fact; I think it's stuck in 3rd. It was no low end power like it use to. I can shift it manually through the gears into 3rd but not into 4th. Manual shift gives crisp shifts. I can not feel it shifting with the selector in OD.
I got to run DataMaster on it and I get a DTC 83 code "TCC control feedback fault". The code is constantly being set from the moment I start the car. I guess this comes from the TCC solenoid?? I know nothing about the inside of the trans. Any suggestions on what sets this code?
JD
JD
FYI. Had a 95 bin with a 94 Trans. The 94 trans doesn't had the sensor and so the pcm set a code and defaulted the trans to some sort of 3rd gear only limp mode.
Uploaded a 94 bin and everything is fine.
JD
JD
WobblySausage
Oct 7, 2015 10:09 AM
