LT4 clutch ok into LT1 motor?
I might be missinformed but is there a stock type upgrade clutch for the lT1 motor like an LT4 clutch? I would like to order parts from Jason Cromer and want to know is such an upgrade is ok. Not looking for any major HP increase and even a stock clutch would be acceptable. Hope you can advise me. Thanks.
yes you can use the LT4 pressure plate but you must use an LT1 disc. For some reason the LT4 disc doesn't work. I have that setup in my car but it isn't holding the power so i'll probably do a spec stage 4 come summer time.
Jul 4, 2005 05:00 PM
