Trans go install need help
Old May 13, 2004 | 09:34 PM
"White Knight"'s Avatar
Alright i broke a clip in the tranny. One of those clips with the little tabs that keep the connection together. Anyone know if i can replace them individaully......it looks like the wires come out because they are loose.......but i don't know how and help would be aprretiated.
Old May 14, 2004 | 06:50 AM
curly's Avatar
Let me guess.... one of the two solenoids that are side to side on the valve body. We did the same thing with my install. We used two very small tie wraps, if they ever break or slip off, the only way I can see is to replace the harness on the valve body. The tie wraps are working so far (keeping fingers crossed).
Old May 14, 2004 | 06:57 AM
Yup that would be the one..........I sure hope i can just change the clip.......i just need to know how the wires come out....they are loose and all......i just am not familiar with that type of electrical clip.......some have those little things that push in the back to hold the wires in, this has a metal slot out the front where it is hooked
Old May 14, 2004 | 09:26 PM
Anybody else have this prob and find a cheap fix? Anyone know how to change the wire harness? is it hard or can it be done with the trans in the car
Old May 14, 2004 | 11:03 PM
12SCNDZ's Avatar
If you're paranoid you can use a tie wrap. I've put hundreds of them back together with broken clips with nothing holding them in....I haven't ever had one come back apart....
Frank
All-trans Transmissions
Old May 14, 2004 | 11:06 PM
blind527's Avatar
i don't have the tools to do it myself, i gotta take it somewhere and have it done, any idea on price ranges for an installation?
Old May 19, 2004 | 09:57 PM
Thanks Frank, I really didn't feel like changing the harness . I'll just put her together and tie it up
They will charge probably 250-350 that is just my guess. they say 4 hours so at 60 bucks an hour that is 240 plus they add some extra. Or maybe you can find someone on here that will do it for less
I'd do it for 100 lol I am on day 4 of the install.........I only get to work on it for like an hour a day......i am way to busy.....half of the time is getting stuff around plus i am cleaning every little part
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
lbrowne
Aug 22, 2002 06:21 PM
