Moser 9" questions
Old May 12, 2004 | 11:19 PM
chrism400's Avatar
Moser 9" questions
I am installing a Moser 9" in my 95 Z28. It seems like the driveshaft is a bit too short now. It is a brand new 1LE aluminum 3 inch driveshaft. Can it be lengthened? How much shaft should go into the trans? I know while it is up on jack stands, the rear is hanging down all the way and the driveshaft is pulling out somewhat.
Old May 13, 2004 | 04:59 AM
SABLT194's Avatar
You should really jack up the rear and get the suspension at its normal ride height. Then you should have at least 1/2" of available driveshaft travel into the transmission. If you'r drag racing and launching hard I would increase that up to about 3/4" of available travel. If you're hanging out over an inch then I would consider getting a longer DS. Hanging out too far will lead to vibration issues and you may loose valuable spline engagement.
JMHO
Steve
Old May 15, 2004 | 08:20 PM
mrz28 73/97's Avatar
Moser 9" question
On your 95 do you have ABS and are you able to keep it once the 9" is installed.
email Dale at DCYZ29@aol.com
Old May 16, 2004 | 02:50 PM
sablt194
What's the pn of the McCloud blow shield you installed I need on for my 97 SS. My name is Dale and you can email me at DCYZ28@aol.com thanks.
Old May 16, 2004 | 11:06 PM
If you're making enough power to require the 9-inch, I'm surprised you are still using the 1LE DS... it isn't going to take a lot of abuse.
If you can determine your required dimensions from the existing DS, I have an almost new Mark Williams 3" chrome moly DS with TH400 input yoke for sale. I could see how it compares to the dimension you need.
Noenav
Mar 1, 2019 07:38 AM
ddr698
Jan 9, 2015 10:05 AM
Victory Racing
Sep 12, 2002 10:40 AM
kev93z28
Aug 19, 2002 12:48 AM
