New Clutch and Flywheel
Old Apr 28, 2004 | 12:27 AM
Poik's Avatar
My clutch is slipping, not too bad, but it makes it so I can't make good launches. So I am going to replace the clutch. Does anyone on here have any suggestions for my new clutch, should I just get the OEM replacement or buy an aftermarket one? Since I am having the clutch installed anyways, should I get a lightened flywheel? If so, what are some good brands I can research. Any posts would be appreciated, thank you.
Old Apr 29, 2004 | 10:55 PM
Bud M's Avatar
SLP sells a steel flywheel that's lighter than stock and a clutch/pressure plate setup that a step above stock. I got mine from TByrne racing.
SLP shows up frequently in group purchases.
Old Apr 30, 2004 | 09:14 PM
nateh's Avatar
The OEM replacements are not bad. They aren't for high horsepower though. I overpowered mine and switched to a Spec. For stock and somewhat higher, I'd go with a stock replacement. They cost a lot less.
You can spend as much as you want.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Jake Bialke
Sep 24, 2015 11:31 AM
