12 bolt or 9" ford rear" pros and cons please
Old May 4, 2004 | 03:29 PM
bluecmaro96's Avatar
which aftermarket rear is best? what are the pros and cons of each, when i need a new rear should i get moser 12 bolt or ford 9"? or what other 12 bolt? thanks for the info
Old May 4, 2004 | 10:59 PM
You might want to try a "search".... this topic gets posted every month or so, and there are some reasonably complete responses in the earlier threads.
Old May 5, 2004 | 01:28 AM
IllusionalTA's Avatar
It really depends on whether or not you have traction control.. If you do then you can get the 9" w/o any loss of ABS and your TCS.. But!! if you don't have traction control then you'll lose abs w/ the 9".. The 12 bolt offer's both the 3 channel (non-TCS) and the 4 channel (TCS).. If you love to beat the snot out of your car then and don't mind the loss of abs/tcs then by all means get a 9" if you just want a upgraded rear for the occasional drag strip outing get the 12 bolt it'll more than suit your needs.. But in my opinion If you need abs it's too late and we all turn the tcs off anyway. so.. Go w/ the 9"
Old May 5, 2004 | 03:21 PM
when i do a search on 12 bolt the search says invalid because 12 is only 2 numbers.
Old May 5, 2004 | 05:44 PM
I tried "9-inch" and got 33 hits. Or.... "12-bolt" or "Moser", or "Strange"..... etc.
maybe2fast
Mar 16, 2015 09:45 AM
cmyname1
Feb 19, 2015 08:38 PM
bowtiepwr
Aug 5, 2002 08:14 AM
FiNSTa
Jul 20, 2002 10:57 PM
Z284ever
46
Jul 2, 2002 07:13 PM
