clutch slipping ??? Or pressure plate weak ?
Old Apr 26, 2004 | 09:13 AM
'02 Collecter TA WS6's Avatar
My '02 Collector Edition has developed an odd problem.
Car has 21,000 miles on it. No track time... just normal street driving / highway.
If I take off hard in 1st gear, reach redline and shift hard to 2nd, the clutch starts slipping and the car doesn't pull anymore. Totall slippage.
I figured the clutch was toast, but at 21000 miles with no drag racing I thought this was odd.
I decided to make some tests. I started off in 2nd and even 3rd gear from dead stop... no slipping. The clutch grabs as soon as the pedal is raised just a little from the floor.
I can romp on it in 1st, 2nd, or 3rd gear while cruising and the car just digs in and pulls... no slip.
The clutch only slips when I hard shift from 1st to 2nd.
This doens't sound like a worn clutch. Sounds like a weak pressure plate perhaps ?
Or slave cylinder screwing up ??
Any thoughts ?
Car has 335hp / 380 TQ as of last dyno about 5 months ago.
Old Apr 27, 2004 | 08:03 PM
Sorry, I didn't realize there was a driveline forum. Thanks for moving it admin.
So are there any thoughts?
Old Apr 28, 2004 | 04:24 PM
Kevin97ss's Avatar
Sounds like a sluggish slave cylinder(slow to return) I hear its a common problem with LS1 clutches. Do a search in the LS1 section under slave cylinder, I think there is a line modification that you can do to correct it.
Kevin
Matt W
Apr 24, 2015 12:54 AM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
