Thumping noise on acceleration
Old May 11, 2004 | 06:13 PM
FuelFC's Avatar
Question Thumping noise on acceleration
Problem:
97 Z-28 4L60 Auto tranny has a thump he says. I crawl my sorry old butt underneath and shake drive shaft we have movement of about 1/8" diametral.
Is there usually that much slop of the drive shaft?
Do these normally wear out?
Bearing or bushing in there? (I've read bushing so that's what I'm assuming.)
Can that be replaced with the rear seal?
How long will this run if driven nicely?
Tranny mount? from what I read this is a problem also.
Can I (HE) change out just the tail stock on the tranny or does he have a lot of other expense and sweat in the Texas sun to go through?
I was surprised it wasn't leaking either. Not one drop or any residue.
Old May 11, 2004 | 09:20 PM
n2ceptor's Avatar
It prob the trans mount... takes about 15-30 minute to change and cost around 20 dollars for stock and 35-40 for a poly...
Old May 11, 2004 | 09:27 PM
unvc92camarors's Avatar
i second this
had the same problem
swapped in a new mount and works just fine
Old May 12, 2004 | 12:53 AM
1BAD86Z's Avatar
trans mount ripped
yeah i remember my first time i ripped my mount sounded like some one was pounding my floor boards with a sledge hammer.
Old May 12, 2004 | 06:47 AM
FuelFC's Avatar
I am still concerned about the slop of shaft fit into the rear of transmission. It sure seems like alot of movement compared to what I am used to.
Thanks I'll (kid) will install mount first and we'll test and post results. Thanks for now.
Can I just remove the torque arm and not see any difference in driving or perfromance? Why is it there then?
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
autoxr166
Sep 25, 2015 04:21 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
