Rebuild or buy new T56 tranny
Subscribe
May 6, 2004 | 02:46 PM
I can get a remanufactured trans with a warranty for about a thousand bucks. How much is the average cost for a rebuild on these transmissions? I know it needs new bearings, syncros and probably an input counter shaft and an output shaft. Where should I take it in Michigan?
Reply
May 7, 2004 | 12:13 AM
From your post it sounds like you broke the same ouput shaft that I did. I could be wrong, a description of your symptoms would be helpful. My output shaft broke where it splined with the main shaft. I lost fifth, sixth and reverse gears. If you think you broke a shaft I would go with a rebuilt with a warranty for a grand.
I replaced the output shaft and a couple of shims and seals. I would guess that I payed about $760 for the output shaft and about $100 for the rest of the parts that I needed. I got the parts for cost plus 10% because I worked for a Jeep dealer at the time and we had a good relationship with the Chevy dealer down the street. My total cost was about $900, but I had acess to a lift and I got lucky with my first t-56 rebuild . It broke at 50K and now it has 101.2K. I hope this helps.
Reply
May 8, 2004 | 08:58 PM
fyi, output shafts are about $250 new. not sure where you found it for 750!
to the orig poster, if you have that much stuff wrong, and can get a reman for 1k, go for it.
Reply
May 8, 2004 | 09:01 PM
**** you are in the detroit area..... D&D in Wixom, just off of wixom road.and west road
call D&D Performance, their trans taken all i have thrown at it to date.
Reply
Subscribe
