12 bolt or 9"
To say either 12 bolt or 9" and the word cheap in the same sentence is a oxymoron.. Both are significantly stronger than the stock rear.. Longevity really depends on who's driving it and the kind of power, clutch, etc your running.. It all can swing it either way.. Expect to pay around 2K for either rear... And from what i have seen on here used one's circulate for about 1500 or so...
IMHO a 9" is the stronger of the 2.. but i may be biased...
the 9inch is stronger i know i have one. if you have an auto then go with a 12 bolt it will hold, but if you have a m6 then the 9 inch is the way to go. you will lose a little more power through the 9 inch but it will be worth it.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
