New G2 Diff Cover, need help with installing please!
Old May 5, 2004 | 09:24 AM
lbrowne's Avatar
Cool New G2 Diff Cover, need help with installing please!
I have a Granatelli G2 diff cover that I bought used from a board member here. I have all the bolts with it and heres my questions:
The center bearing cap bolts, how tight? I think I can just finger tighten them, and then lock em..... (stock cover doesn't have them...)
How tight for the bolts all around the edge of the diff cover...
WHAT TO PUT IN THERE?!?
Thanks!
lbrowne
Old May 5, 2004 | 10:24 AM
GREGG 97Z's Avatar
I have that same cover, bought it used here too a few years ago. I didn't torque the 10 outer bolts, just got them reasonably tight. I dont really think torque specs on them are all that critical. The two preload studs are tightened to 5 ft/lbs though, I called LG to check. I used 2 quarts of 80w90 gear oil and a bottle of GM LSD additive. I think I may go to 80w140 next time since it offers a little more protection for the gears during hard launches plus it's starting to whine now from all the abuse
Old May 5, 2004 | 11:48 AM
lbrowne's Avatar
thanks for the input!
So should I just go straight to 80w140 then?
I would use non-synthetic right?
Has anyone else used that sort of gear oil selection? What brand should I get?
thanks again.
Old May 5, 2004 | 04:11 PM
GREGG 97Z's Avatar
I run mine a lot at the track which is why I was going to go with 80w140, for normal street use I would just use 80w90. I used to use Mobil 1 75/90 but was told the non synthetic is better protection from hard launches because it's thicker. I forget the brand I used last time, non synthetic gear oils are pretty much all the same I'd assume.
Old May 8, 2004 | 09:18 PM
lbrowne's Avatar
what sort of rtv sealant or other product should I use to seal the cover on?
Old May 11, 2004 | 01:08 PM
lbrowne's Avatar
ttt
Old May 11, 2004 | 02:13 PM
2001NBMZ28's Avatar
When I did my TA cover I torqued the pre-load bolts to 5 ft lbs, 25 ft lbs for the cover bolts, and red RTV silicone sealant on the cover.
Old May 13, 2004 | 04:47 PM
lbrowne's Avatar
good stuff, I think for the center screws which are for my bearnig caps or whatever, I'll just finger tighten them and lock them in place. (no one really answered that one yet)
The stock cover don't have them and I run my stock 3.42s in there....
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
thenewkid
Nov 29, 2014 04:54 PM
