2 series carrier
Old May 10, 2004 | 08:39 PM
MaxCamaroZ28's Avatar
2 series carrier
My friend has a set of brand new STRANGE engineering pro-street 4.10 gears. He decided to put 3.73's in his thirdgen instead, but I have a '97 Z28 M6 and drooling over his 4.10s.
His 4.10 gears are for a 2 series carrier, as his car came with 2.73 rearend. He has a 2 series carrier that he's just going to give me in the deal, if I decide to take it. I'm told that with 4.10 ratio to fit in a 2 series carrier, the ring gear is "thicker", and that it will actually make the rearend more durable?
Curious if any of you have heard of this. The "thick ring gear" part is quoted from thunderracing.
Either way, I'll get his 4.10's and carrier cheaper then I would regular 3-series 4.10's...but just wanted your opinions on this.
So if there is no reason why i SHOULDN'T change carriers to get the 4:10s i will.
Old May 12, 2004 | 09:09 AM
anaik's Avatar
There shouldn't be a problem if you use his 2 series carrier with the 4.10 2 series gears. The part that is thicker is the area behind the teeth on the ring gear, where it bolts to the carrier, so it isn't going to make it any stronger. The teeth are where the torque is applied to.
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
Dr. Weir
Aug 2, 2002 02:36 AM
CW 99 Z
Jun 23, 2002 08:30 PM
