what is the backlash for gm superior gears and how do you adjust it?
Old May 3, 2004 | 05:05 PM
bluecmaro96's Avatar
i cant find any write ups on installing gears, me and my buddy did it to my camaro last year and things went great i just dont know if the gm superior gears have the backlash stamped on them, and how do you adjust it? thanks what if you dont adjust backlash? will the gears whine for sure?
Old May 4, 2004 | 06:34 AM
IDOXLR8's Avatar
Re: what is the backlash for gm superior gears and how do you adjust it?
I am a little confused. If you and your buddy did it last year than how do you not know how to adjust backlash. The backlash will differ between gear manufacturers. When my buddy and I installed my Strange gear the backlash was supposed to be set between .008 to .012. We set the backlash at .010. You adjust backlash by adding or subtracting shims. If you don't adjust backlash you more likely to shear some teeth off the pinion or ring gear. Also the rearend will whine like crazy.
Old May 4, 2004 | 08:02 AM
importeater's Avatar
Adjusting the backlash is done by removing shims from one side and installing that same thickness on the other, this moves the ring closer (tighter backlash) or farther (looser backlash) to the pinion. Its important that you put what ever you take out of one side into the other or you will mess your preload all up.
Old May 4, 2004 | 01:25 PM
LiT1_up's Avatar
go to this site and click on yukon installation instructions. see if it helps.
http://www.ringpinion.com/tech/techind.html
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
BPS
9
Mar 5, 2015 10:51 PM
jb4xx
Feb 2, 2015 10:00 PM
