3rd gear Syncro problem
Old May 2, 2004 | 08:13 PM
H/C LS6Z's Avatar
Was wondering why when my car is in 3rd gear (T-56) it will slip out into neutral about 60% of the time? Pretty sure it's the syncro, but what needs to be replaced and what parts need to be purchased? How tough is it to do?
Old May 3, 2004 | 03:29 PM
H/C LS6Z's Avatar
nobody knows what to do about a 3rd gear sycro? c'mmon guys
Old May 4, 2004 | 09:31 PM
Rodrigues's Avatar
When looking down on the tranny face up from the rear, try removing the left torx bit and see if the rod/pin is broke. This holds shifting blocker. If this broke then 3rd gear would pop out, Either that or I would replace the entire 3-4 syncronizer and possibly the gear depending on the damage. Chances are youll only need to replace the slider if that pin isnt the problem. Pin only costs $5 but you will need to take the tranny apart to find where the other half of the pin went.
Old May 5, 2004 | 03:01 AM
H/C LS6Z's Avatar
thanks for the help, will check it out asap, anybody else with any other opinions jump in
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
