M6 - bucking at low speed - normal?
Old May 13, 2004 | 08:50 PM
BPS's Avatar
BPS
Question M6 - bucking at low speed - normal?
I've had this problem for years and thought it was normal but want to double check as I never have this issue with any other standard I've driven.
When driving at low speeds ~ 10 mph, not riding the clutch the car bucks. RPMm's are fine and I'm not near stalling.
I recently upgraded to 4.10 gears so I'm at a higher RPM and it still does it - I have this happen with 3 differnt cams including the stocker so i don't think it's can surge - the tranny mounts look OK.
But it's basically undrivablefrom ~10 MPH and below as I either have to ride the clutch or coast.
The clutch has been replaced - that had no effect.
it's really noticable when making a slow U turn or turning into a gas station - you know - when you have a bit of power but are driving slowly.
So - is this nornal or should I investigate further?
thanks
Old May 14, 2004 | 10:16 AM
Taspeed's Avatar
usually means that its time for a rebuild in the tranny. The old 4 spds would do that when the bearings, and thrust bearing inside of them were bad.
Old May 15, 2004 | 01:36 AM
BPS's Avatar
BPS
what, no one here with an M6 ever drives slowly?
Old May 15, 2004 | 09:12 AM
Valkyn71's Avatar
Mine did this, it also blew out the tranny last week , so ill tell you if it does it with the new one or not.
edman
Mar 13, 2015 09:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
super83Z
Jul 21, 2002 02:43 PM
